Box Sync Problem Notification - File Type Not Supported
Box Sync does not support the following file types (see Which File Types are Ignored and Which are Blocked? for detailed information):
  • Outlook PST files
  • QuickBook files
  • Google Docs/Spreadsheets (web only documents cannot sync to your local machine)
Environment
Resolution Steps
Upload these types of files using the Box website.
Version history
Revision #:
1 of 1
Last update:
‎12-21-2017 11:01 AM
Updated by:
Labels (5)
Contributors
