Box Sync Problem Notification - File Locked By Box
If a collaborator has locked a file on Box and prevented downloads, you will not be able to download and update the file until it is unlocked.
Environment
Resolution Steps
Locate the file on Box, right-click and select Unlock File. Before the file is unlocked, you can view the name of the person who locked the file. Contact this person to coordinate your changes. Once this file is unlocked, use the "Retry All" button found in the problem file window.
Version history
Revision #:
1 of 1
Last update:
‎12-22-2017 09:06 AM
Updated by:
Labels (5)
Contributors
