Box Sync Problem Notification - File Is Locked By Another Application
If a collaborator has locked a file using another application, you will not be able to update the file until the file is unlocked by that application.
Environment
Resolution Steps
Go to the application and unlock the file. If required, contact the file owner to coordinate your changes. Once this file is unlocked by the application, use the "Retry All" button found in problem file window.
Version history
Revision #:
1 of 1
Last update:
‎12-22-2017 09:02 AM
Updated by:
Labels (5)
Contributors
