Box Sync Problem Notification - File Deleted on Box
You see this message in the following situations:
  • When the file is edited offline and you try to delete the item on Box. You see this error message when Box Sync restarts.
  • When the file is deleted on Box and you try to edit the item locally. You see this error message as soon as the conflict is detected.
In either scenario, a parent folder might have been unsynced. An unsync on Box is interpreted as a delete on local. If File X was specifically deleted on Box (as a result of a parent being unsynced or deleted) and edited locally at the same time, then uploading File X to that same location will no longer sync the file. If you upload File X to a different synced folder, that file will reappear locally.
Environment
Resolution Steps
To work around this issue, make a copy of the file and delete the original. Alternately, upload the file via the web app to some other currently synced location and delete the original.
Version history
Revision #:
1 of 1
Last update:
‎12-22-2017 08:54 AM
Updated by:
Labels (5)
Contributors
