Is 74.112.185.136:21 not open anymore?
New Contributor
Hi
I have a setup FTP uploading files from a site i China to BOX on IP address 74.112.185.136:21.
Afterwards we can access the files from Denmark.
This setup stopped working around 20***phone number removed for privacy***. Maybe due to the great chinese firewall or maybe due to this address has been closed by BOX.
I have just tried out connecting from FileZilla and gets the following output:
Status: Disconnected from server
Status: Connecting to 74.112.185.136:21...
Status: Connection attempt failed with "ETIMEDOUT - Connection attempt timed out".
Error: Could not connect to server
Is there any other (new) IP address available to use from China for FTP transfer of files?
I would much appreciate the answer - I hope Smiley Happy
BR Lars Jakobsen, FOSS
New Contributor
Hi
I have a setup which uploads files by use of FTP, from a site in China to BOX, on IP address 74.112.185.136:21.
This setup stopped working around January 12th., maybe due to the great chinese firewall or the address has been closed by BOX.
Is there any other (new) IP address available to use from China for FTP transfer of files or any other help?
I would much appreciate any help.
BR Lars JakobsenSS
Community Manager
Re: Is 74.112.185.136:21 not open anymore?
Hi @Lars_Jakobsen,
Thanks for your post and question!
Check out this article and let us know if that helped your issue!
Your post seems like it may require account specific information/configuration.
For those, you should contact Box Support to help you directly, or for other support options, visit this page.
