Drive Mapping
SOLVED
Go to solution
New Contributor
Drive Mapping
I'm looking to map a drive in windows to one of our Box folders, is there a way to do this?  I tried mapping to the webdav site, but that only gets me to the top level.  Is it possible to map further down?
Valued Contributor
Re: Drive Mapping
Yep. If you add the rest of the path to the end of the webdav url, it will mount a drive to that subfolder precisely. Use url substitution rules for special characters if it doesn't work right away.
New Contributor
Re: Drive Mapping
Thanks, I think I'm running into a special character issue.
Valued Contributor
Re: Drive Mapping
Would you be so kind as to expand on your comment....for those of us mere mortals that can't get to the BoxRing Smiley Happy
Community Manager
Re: Drive Mapping
Hi @jszesq,
I've removed the post you replied to, as it violated our community guidelines. But once I removed it, I realized that your reply looked strange out of context. My apologies!
If anyone is wondering who @jszesq was talking to, that post has been removed.
Sorry to all for any confusion!
Occasional Visitor
Re: Drive Mapping
Hi, could you explain what you mean by Webdav, I am not expert in these matters and just want to find the url to input in the "map network drive" box under file explorer.
Thanks for any help you can give
Max
Community Manager
Re: Drive Mapping
Hi @maxdba,
You can check out this article about Using Box with WebDav here for a walkthrough!
