The Box Feed uses machine learning to provide a constantly-updated personalized collection of content.  It identifies documents and files it deems most relevant to you based on the people and files you work with most, and automatically posts previews of them to your Box interface.  These could be files you’re working or collaborating on, or documents others have created you don’t even know exist (assuming you have permission to view these documents).
Feed assesses each document’s relevance based on what you’re working on and who you work most closely with.  Then Feed presents one centralized view from which you can access, share, sort, and comment on all these documents – in effect automatically curating a collection of your most relevant content
Understanding Box Feed
As you familiarize yourself with Feed you may find it saves you a significant amount of time in your day-to-day activities.  With just a click – or even just a glance – you get a great deal of information about the items that Feed calculates are important to you, and can take appropriate action.  You can:
What’s in your feed and how it gets there
Feed selects, sorts, and displays your most relevant content, regardless of type – documents, images, media files, and so on. Feed assigns relevance to each item based on three factors:
  1. How recently you or someone else worked on it. The more recent a document was created, revised, or even visited, the more relevant Feed considers it.
  2. How many people have accessed or commented upon a file.
  3. Your relationship with whoever touched the file. People who Feed considers the most relevant are the people you work with most closely, as measured by the timeliness and frequency with which you collaborate.
Box alerts you automatically whenever a new post arrives by displaying a colored circle next to the Feed icon in your left navigation bar.  The revised post could be substantial (a newly-created document) or relatively minor (someone just viewed a file you worked on earlier.)  To stop displaying the colored circle, either refresh the page or, in the lefthand navigation, click the Feed folder icon.
To see who acted on a file, what action they took, and when they acted
Feed automatically displays information about each specific post in your feed.  It displays each post in the form of a snapshot of the file, with two lines of information above the snapshot and one line below.
In the two lines above the file preview, on the left, Feed displays the person who accessed the file, and the action he or she took (viewed, updated, and so on).  Feed displays names if they are owners or co-owners of the file (editors, too, if their identity isn’t hidden); otherwise Feed displays an anonymous viewer icon.  In addition, Feed displays, in snipped form, the path to access the file.  Further to the right, Feed displays the date the action took place.
Note   The action Feed lists is not necessarily the most recent action taken on the file.  That’s because the most recent action may have been by someone not relevant to you.  Only the actions of people relevant to you trigger a Feed post.  Similarly, the person listed is not necessarily the creator of the file.  In other words, a comment your manager makes on someone else’s file triggers a post; a file created by someone in an unrelated department, with whom you have a minimal relationship, does not trigger a post.
To locate the Box folder containing the file
Feed displays the path of the posted file, in snipped form, immediately above the preview snapshot.  Click the folder name to display the Box page that includes this folder.
To preview a file right from within Feed, or open it in a separate tab or window
Each Feed post consists of a snapshot preview of the file.  To view each page if it’s a multi-page document, click anywhere in the snapshot within the post.  A menu displays enabling you to click through the file.  To open the file separately, in its original Box location, above the file snapshot click the file name.
To download or share a file, or add it to your favorites
  1. In the top right corner of the post, click the . This displays the Feed action menu.
  2. Click Download, or Share, or Add to Favorites, and proceed as you normally would in Box.Feed post options.png
To comment on a file in your feed
  1. At the bottom of the post, click Add Comment. A text entry box displays.
  2. Type in what you want. Then press
Your comment displays in the Feed post, right underneath the file preview window.
To change the sort order of the posts in your feed
By default, Feed displays your posts in reverse chronological order (that is, most recent first).  But you can instead sort your posts by what Feed deems as most relevant, first.  To do this, above your first post, click the Sort By down arrow, and then click Top.  Feed now displays posts based on the most important action on a file.  This could be a change (such as a comment or update) instead of a view, even if a view happened more recently.
To hide a file from your feed
  2. Click Hide this item. Box immediately removes this post from your Feed.  It ensures the item will not reappear in your feed.  And it takes your action into account when it calculates the relevance of other, similar content in your Feed.
Your comment displays in the Feed post, right underneath the file preview.
Note   This is most effective in blocking an item in which you’re not interested, or which is not as relevant to you as Feed calculated.  You must be an admin, owner, co-owner, or editor of the item to hide it.  Also, hiding it from your Feed does not hide it from anyone else’s Feed.
Keeping Track of What’s Recent and What’s Trending
Whenever you access a file directly from your Feed, Box removes it from your list of posts, to keep your Feed fresh and relevant.  But what if you wish to continue to access this file, without navigating through Box to do so?  That’s what the Recents panel is for.  The Recents panel preserves quick access to these files for you.  It displays, in reverse chronological order, links to the files you previewed or opened from your Feed.
The Recents panel functions the same way as the Recents icon in your lefthand navigation.
Tip   You may want to assign a document as a Favorite, if you want to keep easy access to it in case other, more recent items push it out of the Recents panel.
Feed also gives you insight into what documents are currently most relevant to your organization in general.  It does this via the Trending panel.  The Trending panel lists content that is has seen frequent and recent activity in your enterprise.  This list does not take into account the relevance to you of the people accessing this content.
The Trending panel helps you discover content of potential importance to you that you may not find, or even be aware of, elsewhere in your enterprise.
Note   The Trending panel does not display any files you do not have permission to access, regardless of how “popular” that content may be.
Controlling how Your Activity Shows up in Other People’s Feeds
So far we’ve been talking only about what you see in your Feed.  But what about what your coworkers see?  How does your activity display in their Feeds?  Fortunately, Box Feed gives you substantial flexibility to control how visible you want to be to others.
Just as you are most likely to see updates from the people with whom you collaborate most closely and frequently, from their perspective Feed assigns substantial relevance to your file activity and as a result likely display your updates to them.
Of course, this only applies to the content they have permission to view.  Feed never overrides Box permissions, so it does not display any files you keep private.  Relevance does not enter into it; no one sees anything they do not have specific permission to see.  Shared links also do not display in your feed unless you are specifically added to the document.  You can change specific file permissions directly from Feed.
You can also prevent items in specific folders from appearing in others’ Feeds.
To control who else can access a file
  2. Hover over Who can see this? and then click Manage Collaborators. The Box Collaborators page displays, and you can modify the permissions of anyone you have access to modify, or invite more people to collaborate.
You can also click Manage Folder Permissions to open the Box Folder Settings page and modify access to folder contents as you normally would in Box.  And as with any other file in Box, you can only do this if you are an editor, owner, or co-owner of the file or folder.
To hide activity on a specific folder’s contents from everyone’s feed
  1. In Box, navigate to the folder you want and hover over it.
  2. Click the , and from the menu that displays click Settings. The Folder Settings page displays.
  3. Scroll down to the File View Activity section, and click Hide file view activity in this folder.
Feed will not display any activity on any file stored in this folder.
If your work routinely involves sensitive data – if you work in HR or in legal, for example – you may want to prevent all of your feed activity from showing up in others’ feeds.
To hide all of your Feed activity from others’ feeds
  1. On the top right portion of the screen, go to Account Settings > Sharing. In the page that displays, scroll down to the File View Activity
  2. Check Hide My File View Activity.
If you hide your activity, no action you take ever generates a feed post.
If subsequently you decide to redisplay your file activity in Feed, the actions you take from the moment you redisplay it are reflected in Feed.  Actions you took while you were “hiding” never display.
Box Feed for mobile devices
When you have enabled Feed it also becomes available via your mobile devices.  Feed is the default screen for mobile access.  For both iOS and Android, Feed behavior is as described above.  Other Box mobile functions also remain unchanged.  However, if you want to hide Feed activity around a specific file or folder, you must use the Web app.  You cannot use your mobile device to turn off specific file or folder activity (that is, you cannot hide it via a mobile device).  Once hidden, activity around these items won't display in your feed no matter how you access Box.
Here's what Feed looks like in iOS:iOS Feed.png
And here's what Feed looks like in Android:
Setting Box Feed as your home page
Because Box Feed is designed to help you manage all of your Box content and keep current with your most important documents, you may find that setting Box Feed as your home page can save you additional time.  With Feed as your Box home page you can get up to date as soon as you log into Box and be confident no important file will escape your attention.
To set Box Feed as your home page
  1. In the top right portion of the screen, next to your profile image or initials, click the down arrow.  From the list that displays, click Account Settings.
  2. In the Home section, click the Home Page down arrow, and from the list that displays click Feed.
  1. Click Save Changes.
You can more precisely manage what displays in your feed – just not yet
In this beta, your feed contains Box-generated updates only – meaning you can only see what Box calculates would be most valuable for you to see.  Your input is limited to sorting your posts.  In the future, you will be able to add specific content to the feed.
Related Links
Version history
Revision #:
21 of 21
Last update:
‎12-10-2018 05:22 PM
Updated by:
Contributors
