Box Sync and Box Drive Issues When Installed on the Same Computer
There are known issues with having both Box Sync and Box Drive installed on a single machine and running both applications simultaneously is not supported.
Please be aware of the following known issues if you decide to have both installed on your machine:
  • Box Notes files will be opened by the product that was most recently installed or updated.
  • Icons may not function properly.
Version history
Revision #:
2 of 2
Last update:
‎06-13-2017 05:09 PM
Updated by:
More in this guide:
Go to Guide
