Showing results for
Search instead for
Do you mean
Reply
Occasional Visitor
Re: node.js SDK - basic authentication questions
I think the detail doc here will be helpful oauth-20, at least it's working fine for me to get the refresh/access token at first time, then use the refresh token to generate new access token. (note:the authorization code will expire in 30 seconds after generation. )
