Uploading Files and Folders to Box
New Contributor
Is there any method in which i will give path of Box like Folder1-> SubFolder1 and box will upload my file to that location.
Here, Url be like Folder1->SubFolder1->FileName1.
Or is there any alternative way to provide this kind facility where giving input from client
  1. Path where we want to upload
  2. File which we wants to upload
1 REPLY
Box Employee
Re: Uploading Files and Folders to Box
@deepjadia To upload a file to a specific folder, you have to provide the id for that folder. Based on your example, you would have to know the id for "SubFolder1" to upload a file there.
You can find the folder id for "SubFolder1" by using the Search endpoint. You can limit the search results by specifying "Folder1" as the value of the ancestor_folder_ids parameter, which will limit the results to only items in "Folder1". You can also limit the search results to only folders by setting the type parameter to folder.
