Enterprise ID
Occasional Contributor
Enterprise ID
Hi,
    I notice we can get Enterprise Id through admin console.
   But I want to know is there an api that I can use to get enterprise id??
Also, for each application I created, I can see the application Id in the developer console, is there an application id for each application??
   Thank you.
1 REPLY
Box Employee
Re: Enterprise ID
@emilyfu Unfortunately, we don't have an API to get an organization's enterprise id.
Just to confirm, when you refer to the application id, do you mean the client id for the application?
