BoxUser#getMemberships() method raises an UnsupportedOperationException
Occasional Visitor
I was testing the sample deleting group members of each Box user, but an exception occurred.
It occurs with the frequency of deleting 5 group members of 3000 users.
Also, it is executed under multithreading.
The version of java sdk is 2.4.0
It occurred with the following code.
for(BoxGroupMembership.Info member : user.getResource().getMemberships()) {
	if(member.getGroup().getName().equals(group.getName())) {
		member.getResource().delete();
I confirmed with the debugger that it turned out that there was a difference in response.
How can I avoid this?
Response without exception
    "total_count": 1,
    "entries": [{
        "type": "group_membership",
        "id":***phone number removed for privacy***",
        "user": {
            "type": "user",
            "name": "\u5c71\u7530 \u524a\u9664 1183",
            "login": "***email address removed for privacy***"
        "group": {
            "type": "group",
            "id": "***number removed for privacy***",
            "name": "group05"
        "role": "member"
    "limit": 100,
    "offset": 0
Response with exception
    "total_count": 1,
    "entries": {
        "1": {
            "user": {
                "type": "user",
                "name": "\u5c71\u7530 \u524a\u9664 0084",
            "group": {
                "type": "group",
                "name": "group04"
            "role": "member"
    "limit": 100,
    "offset": 0
