Box Api integration in Drupal custom module
Occasional Contributor
Hello Everyone,
I have developed a module in drupal 7 for integrating Box different API. The following  feature, i have integrated with this module.
1. JWT access token method for fetching data. Implement JWT zend framework library in Drupal module.
2. Fetching folder with all files details and metadata details using search query.
3. Creating/updating files in Box , using API call.
4. Creating/Updating metadata of files using API call.
5. Download files using API call.
6. Creating report with different metadata search filters.
Cheers,
Vijeesh
1 REPLY
New Member
Re: Box Api integration in Drupal custom module
Could we view the module files to take a look at what you have come up with?
